TPS54560B-Q1: TPS54560B-Q1 24V output Circuit is not working
Part Number: TPS54560B-Q1
Hey ,
I have designed a buck convertor using TPS54560B-Q1, I have took a reference design from the webench designer tool, I have used the same values as mentioned in it , I have attached the image of the circuit below please find it,
The issue is am not able to measure the output Voltage as 24V, Instead am getting an output voltage of 0.9V. While simulating it gives the required output but when we try it we are not getting the required output Can you help us fix this issue.
Waiting for your reply
Thanking you.
PFA
