BQ20Z90: gg file error
Part Number: BQ20Z90
hi
I have a questions.
1. gg file to ev2300, if the message below appears, I would like to know why.
   - Mismatched Target name in GG file! Do you want to continu?
2. If the gg file can be damaged while using bq20z90, why is it damaged?
  • Hello Kim,
    Can you share the .gg file you're trying to upload? The device name is not the same as the device you're trying to upload to, maybe you used the wrong configuration file for the gauge.
    Sincerely,
    Wyatt Keller
  • Please check the attachment.
     I was wondering if the gg file was damaged during use, and it was said that the wrong configuration file may have been used in the gauge, but we have never changed the gg file created once.
    I could have and I wonder if even if the file gg damaged during use, the gauge uses the wrong configuration file, we could change the hanjeokyi gg files generated once.
    ​Thanks
  • Hello Kim,
    Either the .gg file was changed so the target was changed, or the gauge information was somehow corrupted/changed so the .gg is the same but doesn't match the gauge.
    Can you test with any other gauges, what's the occurrence rate?
    Sincerely,
    Wyatt Keller
