BQ27426: BQ27426 FUEL GUAGE
Part Number: BQ27426
Hello Team,
i am currently working on BQ27426 fuel guage ,Am unable to read the IC bq27426,since am able to write correctly,
1.What are the major steps to wake-up the IC,such as sending commands for sealed to unsealed mode,what are the key steps should i follow by using I2C protocol ?
2.What is the read sequence should i follow to read SOH ,TEMPERATURE registers,is it neccessary to read both 16-bit registers(0x20,0x21)SOH, at a time or can i read 8-bit register once a time
3.Is there any device id or chip id to read the sensor,what is the register should i read
4.As am able to write to BQ27426,but am unable to read from device,where can i expect the problem(software/hardware)..
could you resolve my issue as soon as possible.
thanks in advance
suraj.n
