Team,
Customer is using TPS4H160-Q1 for relay driving. But they found that an issue that when putting TPS4h160-Q1 in -20C°, out3 has no output after enabled.
Could you help to give the guideline? Thanks!
Team,
Miles,
Could you prove more information? Specifically:
About the #1,#2,#4 question, I would learn further.
Based on #2 question, customer says he device would return back to normal after the temperature returns to normal. And they have tested two boards, and only one board has this issue.
