Part Number: TPS25947
Other Parts Discussed in Thread: TPS2595
Hi Sir,
may we know that TPS25947 series has an output discharge function? if there this function, could we know that the impedance value internal? thanks.
Hi Tommy,
Thanks for reaching out!
TPS25947 series does not have QOD feature. But has reverse current blocking feature that can block reverse current from OUT to IN pin . So when input supply is disconnected and output cap is charged the device will block the reverse current flow into supply thus protecting it.
We have a device TPS2595 that supports QOD feature . Please also check this device.
Let me know any further questions .
Kunal Goel
Check our new device TPS25947 at
Fast Role Swap, Linear ORing with TPS25947 and LM73100 in USB Type-C systems
