BQ24600: Battery discharge current after Charge completed
Part Number: BQ24600
Hello to TI team ,
      1.  I would like to know leakage current to the IC from Battery after charge procedure completed  (IC supply  present) ?
      2.  I would like to know leakage current to the IC from Battery  without P.S connection  ?.
      3.  Is  State of /PG pin changes after charge completed ?
B.R
Alex Burtakov
  • Hi Alexander,
    1.  This specification is not characterized as battery leakage current is not a concern when adapter is present.
    2. This info is in the electrical characteristics table under Quiescent current section (refer to Ibat spec)
    3. /PG pin indicates if a valid input source is connected. It will not detect end of charge. The STAT pin will accomplish this.
