LP8866-Q1: Power management forum
Part Number: LP8866-Q1
Because recently LP8863 out of stock!
So many RD want to change LP8863 to LP8866,
Could you explain the difference in settings?
For example, will its PWM design parameters be different? or other
What I currently know is "Only LP8863-Q1 supports controlling the LED brightness each channel individually. The minimum controllable series LED number on each driver depends on the topology and the VF of LED and it can support 1 LED using SEPIC topology."
