Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
DRV103: Alternative to DRV103H. PWM low-side (or high-side) valve drivers
Part Number: DRV103
I'm looking for alternative to alternative to DRV103H for 24V, PWM, Low-side or High-side valve drivers. Can you suggest latest PWM valve driver IC?
  1. Output voltage: 24V
  2. Output current: 1A
  3. Output type: PWM
  4. Low-side or High-side valve drivers
  5. Good to have: Output current sense  (To indicate whether Valve is ON or OFF)
