Other Parts Discussed in Thread: LM3409, TPS92512
The availabilty of this part is none at this moment.
Is there a part that has (almost) the same specs and is pin compatible to this part?
With kind regards,
Jeroen Gollenbeek
There is no pin compatible device. You can consider LM3409 which is similar but is a controller (external PFET), or TPS92512/3.
Sumeet
Hello Sumeet,
Thanks for your quick response, do you have any other ideas how we can aquire this component?
With kind regards,
Jeroen Gollenbeek
Hello Jeroen,
If you need a small quantity (<50 units), I might be able to do something towards the end of this week. However for anything more, you would need to go by the lead times provided by TI or your distribution vendor.
Sumeet
