TPS25947: Does the ILM pin can change the current limit setting on line by parallel resistor ?
Part Number: TPS25947
Hi Team,
As title, for TPS25947, does the ILM pin can change the current limit setting on line by parallel resistor ?
Now my customer is surveying the solution, 4~9Vin / 2A Max., and can adjust the current limit setting during on line.
They will use EC or MCU's GPIO pin to determine the resistor parallel together or not.
Kai Lai
