TPS7A47: TPS7A4701 CNR capacitor value
Part Number: TPS7A47
Hello team,
My customer is using TPS7A4701. He would like faster start up when EN pin is applied. So he would like to use 1000pF at NR pin, tied to GND. He doesn't need high noise performance  of TPS7A4701 since the load is a heater (resistor).
Is it possible to use 1000pF at NR pin?  If 1000pF is used, do the  big ripple happen  or do the output of TPS7A4701 is stopped?
Your advice would be so appreciated.
Akihisa Tamazaki
