TPS92310-23FB: Modifying the design for 4 Leds
Part Number: TPS92310-23FB
Other Parts Discussed in Thread: TPS92310, LP8866EVM, TPS92010EVM-631, TPS92010
Hi Team,
Can you please check and advise with following request?
Design example 7 led VLED is designed to be 21V. I need a design with 4 led Vled 12V Pout = 4-5W PF> 90. Can it be obtained by changing the transformer used in the circuit for this? Is it possible to send the eval board design card with 4 led Vled 12V output using TPS92310?
Thanks in advance
Best Regards
Furkan Sefiloglu
