Hi Ti Team,
TLC59284 is found to be easily affected by external interference in the application, leading to LED flashing. Please help to determine whether you have any way to improve this problem. thank you.
Hi Ti Team,
Hi Ken,
Could you describe more about the issue and what is the external interference you mentioned? We need to determine the cause for flicking firstly. Here are many reasons cause the issue, like unstable VOUT, unpredictable channel on/off or wrong signal on BLANK. Could you help to capture the waveform for the VCC / VLED / VOUTx / BLANK when flicker happen?
Hi Jt,
Could you help to share the schematic? The large noise on VCC and BLANK is unacceptable. What is the external interference cause these noise. I think there may need add some capacitor on these pins to filter the noise.
we have attached LED driver schematic , when LED driver standby , we turn off/on switch on PCBA or ESD discharge, LED driver pin VCC 3.3V ,BLANK, LAT,SCLK,SIN have external interference , LED flick , and LED driver pin waveform in the ppt file last time
