Other Parts Discussed in Thread: TPS22950
I am using TPS22963C on a design and would like to know the expected behavior under a fault condition. The enable pin is pulled up to Vin in this application. If Vout is shorted to ground downstream of the load switch, what is the expected behavior? Will it go into thermal shutdown and disable the switch?
Thanks!
Emma
