Hi TI team
The TI document says "VOK: This bit tracks when the gauge measures the battery's voltage. This bit is normally set when charging/discharging starts, and is cleared when discharging stops. The gauge has detected that the battery voltage has stabilized, and has taken the OCV measurement. It is a good way to track when OCV measurements occur.
I find that in some case(randomly), the VOK will not set 1 when charging start. This will cause Qmax will not be updated after full charge. Could you tell which condition will cause VOK doesn't set 1?
Neo
