Hi team,
Could you help to provide the cost-optimized replacement for LTC3636? I think TPS541620 could be one of the option.
Thanks.
Hi team,
Thanks.
It is possible to use the TPS541620 as a cost optimized replacement for the LTC3636.
It will depend on the max input voltage rating needed in the application.
There is an evm in stock www.ti.com/.../TPS541620EVM
Hi David,
Thanks for the comments.
What about the Q-1 device? Do you have any recommendation?
The TPS541620 is not Q1 qualified and I do not know of plans for Q1 qualification.
What are the key specs needed for the Q1 devices, 5V input, 12V input voltages, Output current etc
