UCD3138ACCEVM149: the example 'LLCHBFirmware-1.2' cannot be build
Part Number: UCD3138ACCEVM149
Other Parts Discussed in Thread: UCD3138A, UCD3138, FUSION-DIGITAL-POWER-STUDIO
I bought a UCD3138ACCEVM149 to evaluate the soft for UCD3138A chip.
To do it more efficiently, I download the file ‘LLCHBFirmware-1.2’.
Of course, the file ‘UCD3138_LLC_HB_UCD3138A.x0’ of it can be download to UCD3138ACCEVM149 and operate correctly. And we can watch and config it through ‘FUSION-DIGITAL-POWER-STUDIO’.
However, when I build the project (not revised), many errors happened. So, I check the issue on help center of TI and followed some measures as following:
  1. Uninstalled the newest version of CCS(10.2.0.00009) and installed a old version of CCS(2.0.00050);
  2. Install the ARM compiler version of 5.2.5
  3. Change the Designate code state from 16 to 32
But there are still many warnings and errors as following, I am confused.
Would you please help with this problem?
**** Build of configuration UCD3138A for project UCD3138_LLC_HB ****
"C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
'Building target: UCD3138_LLC_HB_UCD3138A.out'
'Invoking: ARM Linker'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=32 --abi=ti_arm9_abi -O2 -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k -z -m"UCD3138_LLC_HB_UCD3138A.map" --heap_size=10 --stack_size=200 -i"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/lib" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" --reread_libs --define=UCD3138=1 --display_error_number --warn_sections --xml_link_info="UCD3138_LLC_HB_linkInfo.xml" --rom_model -o "UCD3138_LLC_HB_UCD3138A.out" "./UART_Auto_Baud.obj" "./configuration_functions.obj" "./constants.obj" "./cyclone_global_variables_defs.obj" "./fault_handler.obj" "./flash.obj" "./gpio.obj" "./init_adc12.obj" "./init_cpcc.obj" "./init_current_sharing.obj" "./init_dpwms.obj" "./init_fault_mux.obj" "./init_filters.obj" "./init_front_ends.obj" "./init_loop_mux.obj" "./init_miscellaneous.obj" "./init_watchdog.obj" "./interrupts.obj" "./main.obj" "./pmbus_topology.obj" "./scale.obj" "./software_interrupt.obj" "./software_interrupt_wrapper.obj" "./standard_interrupt.obj" "./store_restore_functions.obj" "./uart.obj" "./Device/UCD3138A/Source/clear_program_flash.obj" "./Device/UCD3138A/Source/load_UCD3138A.obj" "./Driver/Pmbus/pmbus_command_indexes.obj" "./Driver/Pmbus/pmbus_common.obj" "./Driver/Pmbus/pmbus_driver.obj" "../cyclone.cmd" "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd" "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd"  -llibc.a -llibc.a
<Linking>
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 21: error #10263:
   VECS memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 21: error #10264:
   VECS memory range overlaps existing memory range VECS
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 25: error #10263:
   ROM memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 25: error #10264:
   ROM memory range overlaps existing memory range ROM
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 26: error #10263:
   SINE memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 26: error #10264:
   SINE memory range overlaps existing memory range SINE
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 27: error #10263:
   EXP memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 27: error #10264:
   EXP memory range overlaps existing memory range EXP
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 32: error #10263:
   PFLASH memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 32: error #10264:
   PFLASH memory range overlaps existing memory range PFLASH
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 33: error #10263:
   DEVICEID memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 33: error #10264:
   DEVICEID memory range overlaps existing memory range DEVICEID
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 34: error #10263:
   FIXTFA memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 34: error #10264:
   FIXTFA memory range overlaps existing memory range FIXTFA
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 35: error #10263:
   FIXCONST memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 35: error #10264:
   FIXCONST memory range overlaps existing memory range FIXCONST
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 36: error #10263:
   FLASHSUM memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 36: error #10264:
   FLASHSUM memory range overlaps existing memory range FLASHSUM
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 42: error #10263:
   DFLASH memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 42: error #10264:
   DFLASH memory range overlaps existing memory range DFLASH
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 55: error #10263:
   TESTER memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 55: error #10264:
   TESTER memory range overlaps existing memory range TESTER
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 56: error #10263:
   RAM memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 56: error #10264:
   RAM memory range overlaps existing memory range RAM
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 57: error #10263:
   STACKS memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 57: error #10264:
   STACKS memory range overlaps existing memory range STACKS
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 58: error #10263:
   ROMLOCK memory range has already been specified
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 58: error #10264:
   ROMLOCK memory range overlaps existing memory range ROMLOCK
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 98: warning #10190-D:
   absolute symbol "_StackUSER_" being redefined
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 99: warning #10190-D:
   absolute symbol "_StackFIQ_" being redefined
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 100: warning #10190-D:
   absolute symbol "_StackIRQ_" being redefined
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 101: warning #10190-D:
   absolute symbol "_StackABORT_" being redefined
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 102: warning #10190-D:
   absolute symbol "_StackUND_" being redefined
"C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd", line 103: warning #10190-D:
   absolute symbol "_StackSUPER_" being redefined
"../cyclone.cmd", line 70: error #10099-D: program will not fit into available
   memory.  placement with alignment fails for section ".text" size 0x82b0 .
   Available memory ranges:
   PFLASH       size: 0x7f38       unused: 0x7a12       max hole: 0x7a0c
>> Compilation failure
makefile:179: recipe for target 'UCD3138_LLC_HB_UCD3138A.out' failed
error #10010: errors encountered during linking; "UCD3138_LLC_HB_UCD3138A.out"
   not built
gmake: *** [UCD3138_LLC_HB_UCD3138A.out] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
    Sorry for the confusion caused.
    You have mentioned that you have " installed an old version of CCS(2.0.00050)".
    The version of CCS that is fully tested for the UCD3138 platform is the CCS version 6 (Or  rev 7).
    Please download the right version of CCS and try again.
    Also the project should be mostly set to code state 16 (Thumb mode).
    Only a few files should be configured to compile as state 32 (ARM mode).
    The only state 32 file are : interrupts.c, standard_interrupt.c, software_interrupt.c, clear_program_flash.c
    the rest should stay in state 16.
    Hope this helps.
  • Hi, Dear Bolurian
    thank u very much for the reply.
    I followed the steps you have suggested.
    1. installed CCS version 6 (6.2.0.00050 )
    2. set the project to code state 16 (Thumb mode)
    3. set the files (interrupts.c standard_interrupt.c  software_interrupt.c in root folder and clear_program_flash.c in device/UCD3138A/source) to code 32  (ARM mode).
    4. build the project.
    while this time errors happen at linking stag (all to cyclone_A_headers.cmd), as following
    looking forward to your help.
    with best regards!
    **** Clean-only build of configuration UCD3138A for project UCD3138_LLC_HB ****
    "C:\\ti\\ccsv6\\utils\\bin\\gmake" -k clean
    DEL /F "UCD3138_LLC_HB_UCD3138A.out" "UCD3138_LLC_HB_UCD3138A.hex"
    DEL /F "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\UART_Auto_Baud.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\configuration_functions.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\constants.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\cyclone_global_variables_defs.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\fault_handler.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\flash.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\gpio.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\init_adc12.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\init_cpcc.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\init_current_sharing.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\init_dpwms.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\init_fault_mux.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\init_filters.d"
    DEL /F "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\init_front_ends.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\init_loop_mux.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\init_miscellaneous.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\init_watchdog.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\interrupts.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\pmbus_topology.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\scale.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\software_interrupt.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\software_interrupt_wrapper.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\standard_interrupt.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\store_restore_functions.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\uart.d"
    DEL /F "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\Device\UCD3138A\Source\clear_program_flash.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\Driver\Pmbus\pmbus_command_indexes.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\Driver\Pmbus\pmbus_common.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\Driver\Pmbus\pmbus_driver.d"
    DEL /F "UART_Auto_Baud.obj" "configuration_functions.obj" "constants.obj" "cyclone_global_variables_defs.obj" "fault_handler.obj" "flash.obj" "gpio.obj" "init_adc12.obj" "init_cpcc.obj" "init_current_sharing.obj" "init_dpwms.obj" "init_fault_mux.obj" "init_filters.obj" "init_front_ends.obj" "init_loop_mux.obj" "init_miscellaneous.obj" "init_watchdog.obj" "interrupts.obj" "load_UCD3138.obj" "main.obj" "pmbus_topology.obj" "scale.obj" "software_interrupt.obj" "software_interrupt_wrapper.obj" "standard_interrupt.obj" "store_restore_functions.obj" "uart.obj" "Device\UCD3138A\Source\clear_program_flash.obj" "Device\UCD3138A\Source\load_UCD3138A.obj" "Driver\Pmbus\pmbus_command_indexes.obj" "Driver\Pmbus\pmbus_common.obj" "Driver\Pmbus\pmbus_driver.obj"
    DEL /F "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\load_UCD3138.d" "C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\Device\UCD3138A\Source\load_UCD3138A.d"
    C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138A\UCD3138_LLC_HB_UCD3138A.out が見つかりませんでした。
    C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\Device\UCD3138A\Source\clear_program_flash.d が見つかりませんでした。
    C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\load_UCD3138.d が見つかりませんでした。
    C:\ti\DigitalPower\LLCHBFirmware-1.2\Firmware\LLC\LLC_HB\UCD3138\Device\UCD3138A\Source\load_UCD3138A.d が見つかりませんでした。
    'Finished clean'
    'Building file: ../UART_Auto_Baud.c'
    'Invoking: ARM Compiler'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/UART_Auto_Baud.d" "../UART_Auto_Baud.c"
    'Finished building: ../UART_Auto_Baud.c'
    'Building file: ../configuration_functions.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/configuration_functions.d" "../configuration_functions.c"
    'Finished building: ../configuration_functions.c'
    'Building file: ../constants.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/constants.d" "../constants.c"
    'Finished building: ../constants.c'
    'Building file: ../cyclone_global_variables_defs.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/cyclone_global_variables_defs.d" "../cyclone_global_variables_defs.c"
    'Finished building: ../cyclone_global_variables_defs.c'
    'Building file: ../fault_handler.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/fault_handler.d" "../fault_handler.c"
    'Finished building: ../fault_handler.c'
    'Building file: ../flash.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/flash.d" "../flash.c"
    'Finished building: ../flash.c'
    'Building file: ../gpio.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/gpio.d" "../gpio.c"
    'Finished building: ../gpio.c'
    'Building file: ../init_adc12.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/init_adc12.d" "../init_adc12.c"
    'Finished building: ../init_adc12.c'
    'Building file: ../init_cpcc.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/init_cpcc.d" "../init_cpcc.c"
    'Finished building: ../init_cpcc.c'
    'Building file: ../init_current_sharing.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/init_current_sharing.d" "../init_current_sharing.c"
    'Finished building: ../init_current_sharing.c'
    'Building file: ../init_dpwms.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/init_dpwms.d" "../init_dpwms.c"
    'Finished building: ../init_dpwms.c'
    'Building file: ../init_fault_mux.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/init_fault_mux.d" "../init_fault_mux.c"
    'Finished building: ../init_fault_mux.c'
    'Building file: ../init_filters.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/init_filters.d" "../init_filters.c"
    'Finished building: ../init_filters.c'
    'Building file: ../init_front_ends.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/init_front_ends.d" "../init_front_ends.c"
    'Finished building: ../init_front_ends.c'
    'Building file: ../init_loop_mux.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/init_loop_mux.d" "../init_loop_mux.c"
    'Finished building: ../init_loop_mux.c'
    'Building file: ../init_miscellaneous.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/init_miscellaneous.d" "../init_miscellaneous.c"
    'Finished building: ../init_miscellaneous.c'
    'Building file: ../init_watchdog.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/init_watchdog.d" "../init_watchdog.c"
    'Finished building: ../init_watchdog.c'
    'Building file: ../interrupts.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=32 --abi=ti_arm9_abi -O1 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/interrupts.d" "../interrupts.c"
    'Finished building: ../interrupts.c'
    'Building file: ../main.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --preproc_with_compile --preproc_with_comment --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --pp_directory="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138" "../main.c"
    'Finished building: ../main.c'
    'Building file: ../pmbus_topology.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/pmbus_topology.d" "../pmbus_topology.c"
    'Finished building: ../pmbus_topology.c'
    'Building file: ../scale.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/scale.d" "../scale.c"
    'Finished building: ../scale.c'
    'Building file: ../software_interrupt.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=32 --abi=ti_arm9_abi -O1 --opt_for_speed=5 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/software_interrupt.d" "../software_interrupt.c"
    'Finished building: ../software_interrupt.c'
    'Building file: ../software_interrupt_wrapper.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/software_interrupt_wrapper.d" "../software_interrupt_wrapper.c"
    'Finished building: ../software_interrupt_wrapper.c'
    'Building file: ../standard_interrupt.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=32 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/standard_interrupt.d" "../standard_interrupt.c"
    'Finished building: ../standard_interrupt.c'
    'Building file: ../store_restore_functions.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/store_restore_functions.d" "../store_restore_functions.c"
    'Finished building: ../store_restore_functions.c'
    'Building file: ../uart.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/uart.d" "../uart.c"
    'Finished building: ../uart.c'
    'Building file: C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Source/clear_program_flash.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=32 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/Device/UCD3138A/Source/clear_program_flash.d" --obj_directory="Device/UCD3138A/Source" "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Source/clear_program_flash.c"
    'Finished building: C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Source/clear_program_flash.c'
    'Building file: C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Source/load_UCD3138A.asm'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/Device/UCD3138A/Source/load_UCD3138A.d" --obj_directory="Device/UCD3138A/Source" "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Source/load_UCD3138A.asm"
    'Finished building: C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Source/load_UCD3138A.asm'
    'Building file: C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus/pmbus_command_indexes.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/Driver/Pmbus/pmbus_command_indexes.d" --obj_directory="Driver/Pmbus" "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus/pmbus_command_indexes.c"
    'Finished building: C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus/pmbus_command_indexes.c'
    'Building file: C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus/pmbus_common.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/Driver/Pmbus/pmbus_common.d" --obj_directory="Driver/Pmbus" "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus/pmbus_common.c"
    'Finished building: C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus/pmbus_common.c'
    'Building file: C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus/pmbus_driver.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Header" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus" --include_path="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k --preproc_with_compile --preproc_dependency="C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/LLC/LLC_HB/UCD3138/Driver/Pmbus/pmbus_driver.d" --obj_directory="Driver/Pmbus" "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus/pmbus_driver.c"
    'Finished building: C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Driver/Pmbus/pmbus_driver.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv4 --code_state=16 --abi=ti_arm9_abi -O2 -g --define=UCD3138A=1 --diag_warning=225 --display_error_number -k -z -m"UCD3138_LLC_HB_UCD3138A.map" --heap_size=10 --stack_size=200 -i"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/lib" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.5/include" --reread_libs --define=UCD3138=1 --display_error_number --warn_sections --xml_link_info="UCD3138_LLC_HB_linkInfo.xml" --rom_model -o "UCD3138_LLC_HB_UCD3138A.out" "./UART_Auto_Baud.obj" "./configuration_functions.obj" "./constants.obj" "./cyclone_global_variables_defs.obj" "./fault_handler.obj" "./flash.obj" "./gpio.obj" "./init_adc12.obj" "./init_cpcc.obj" "./init_current_sharing.obj" "./init_dpwms.obj" "./init_fault_mux.obj" "./init_filters.obj" "./init_front_ends.obj" "./init_loop_mux.obj" "./init_miscellaneous.obj" "./init_watchdog.obj" "./interrupts.obj" "./main.obj" "./pmbus_topology.obj" "./scale.obj" "./software_interrupt.obj" "./software_interrupt_wrapper.obj" "./standard_interrupt.obj" "./store_restore_functions.obj" "./uart.obj" "./Device/UCD3138A/Source/clear_program_flash.obj" "./Device/UCD3138A/Source/load_UCD3138A.obj" "./Driver/Pmbus/pmbus_command_indexes.obj" "./Driver/Pmbus/pmbus_common.obj" "./Driver/Pmbus/pmbus_driver.obj" "../cyclone_headers.cmd" "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A.cmd" "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd" -llibc.a -llibc.a
    <Linking>
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 30: error #10263:
    LOOP_MUX memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 30: error #10264:
    LOOP_MUX memory range overlaps existing memory range LOOP_MUX
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 31: error #10263:
    FAULT_MUX memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 31: error #10264:
    FAULT_MUX memory range overlaps existing memory range FAULT_MUX
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 32: error #10263:
    UART0 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 32: error #10264:
    UART0 memory range overlaps existing memory range UART0
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 33: error #10263:
    UART1 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 33: error #10264:
    UART1 memory range overlaps existing memory range UART1
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 34: error #10263:
    ADC memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 34: error #10264:
    ADC memory range overlaps existing memory range ADC
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 35: error #10263:
    DPWM3 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 35: error #10264:
    DPWM3 memory range overlaps existing memory range DPWM3
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 36: error #10263:
    FILTER2 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 36: error #10264:
    FILTER2 memory range overlaps existing memory range FILTER2
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 37: error #10263:
    DPWM2 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 37: error #10264:
    DPWM2 memory range overlaps existing memory range DPWM2
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 38: error #10263:
    FE_CTRL2 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 38: error #10264:
    FE_CTRL2 memory range overlaps existing memory range FE_CTRL2
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 39: error #10263:
    FILTER1 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 39: error #10264:
    FILTER1 memory range overlaps existing memory range FILTER1
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 40: error #10263:
    DPWM1 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 40: error #10264:
    DPWM1 memory range overlaps existing memory range DPWM1
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 41: error #10263:
    FE_CTRL1 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 41: error #10264:
    FE_CTRL1 memory range overlaps existing memory range FE_CTRL1
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 42: error #10263:
    FILTER0 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 42: error #10264:
    FILTER0 memory range overlaps existing memory range FILTER0
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 43: error #10263:
    DPWM0 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 43: error #10264:
    DPWM0 memory range overlaps existing memory range DPWM0
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 44: error #10263:
    FE_CTRL0 memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 44: error #10264:
    FE_CTRL0 memory range overlaps existing memory range FE_CTRL0
    >> Compilation failure
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 45: error #10263:
    MISC_ANALOG memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 45: error #10264:
    MISC_ANALOG memory range overlaps existing memory range MISC_ANALOG
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 46: error #10263:
    PMBUS memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 46: error #10264:
    PMBUS memory range overlaps existing memory range PMBUS
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 47: error #10263:
    GIO memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 47: error #10264:
    GIO memory range overlaps existing memory range GIO
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 48: error #10263:
    TIMER memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 48: error #10264:
    TIMER memory range overlaps existing memory range TIMER
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 49: error #10263:
    MMC memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 49: error #10264:
    MMC memory range overlaps existing memory range MMC
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 50: error #10263:
    DEC memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 50: error #10264:
    DEC memory range overlaps existing memory range DEC
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 51: error #10263:
    CIM memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 51: error #10264:
    CIM memory range overlaps existing memory range CIM
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 52: error #10263:
    SYS memory range has already been specified
    "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/cyclone_A_headers.cmd", line 52: error #10264:
    SYS memory range overlaps existing memory range SYS
    not built
    It seems like besides the "cyclone_A_headers.cmd" file in "C:/ti/DigitalPower/LLCHBFirmware-1.2/Firmware/Device/UCD3138A/Linker/" directory, you have another "cyclone_headers.cmd" file that is linked/included into your configuration/build.
    Please find and exclude the other "cyclone_headers.cmd" file from your configuration/build by right clicking on the other "cyclone_headers.cmd" file and choose "Exclude from the Build" and then recompile.
