I am using the part LMR36506MSC5RPERQ1 in my design .
I would like to understand the following things.
1. What copper thickness, should I plan if I am using it on a 2 layer board
2. For the fixed output version, can the MODE pin be connected to VCC or is it advisable to connect it to GND? Is there any preference?
3. The land pattern for the corner pads are 'L" shaped. What is the impact if the land pattern is made as rectangular pads instead?
S.Ramamani
