Hi Team,
1.My doubt is we can only configure the device either with Grayscale configuration or FC-BC-DC am I right ?
2.what is the purpose of blank signal when we are using FC-BC-DC configuration?
Figure 2 in date sheet is little confuse.
1.before configuring the device blank goes High and we can see the output on(assuming that configuration is done at rising edge of 288 sclk and latch high) how it is on?
2. I understood that blank is used for resting PWM count which is used for gray scale, how it is applicable for FC-BC-DC? if so, how much time it should be high. how to configure?
3. In first cycle blank goes high in 3 sclk and in second cycle it is high?
