BQ24610: Paralleling mosfets on the ACFETs
Part Number: BQ24610
I want to add a parallel mosfet to each these mosfets, is it possible or is there any way implement this feature with N-Channel FETs? Current will be higher than 10 Amps on the adapter side so I want to lower the resistance and distribute the heat. Do you have any suggestions?
Thanks in advance.
