I have the same problem. It would be great if you can share the solution.
e2e.ti.com/.../ucc21750-simulation-with-ltspice
Welcome to E2E!
The issue you are referring to was related to the circuit as there were some wrong connections that would not let the simulation run. The model file for the UCC21750 that can be downloaded from the product folder through TI.com should not have a problem in LTSpice.
I can give some recommendation to find the issue and get the simulation running:
If simulation error cannot be found feel free to reply to this comment with a screenshot of the circuit being simulated.
Andy Robles
