Other Parts Discussed in Thread: LM25184
We are targeting a similar application as described in linked thread, with the following specs: 12Vin 24Vout Iout 0.2A per channel, 2channels. Transformer specs are Lpri, 24µH 1:2 ratio, 330nH leakage
However we would like to use 2 separate identical transformers for each channel, with paralleled primaries. Would a single LM25184 be able to drive and regulate both supplies? Or do you recommend using a single LM25184 per transformer?
Xavier
