Part Number: BQ33100
Other Parts Discussed in Thread: BQ24640
I used BQ33100 part for 5 supercaps , As mentioned in data it automatically calculate ESR & capacitance in 15 days .
Q1. Can I disable LLEN pin through software .if yes , how?
Q2. what is the output voltage of CHG pin when LLEN enable & when disable .(we are facing random behavior of this pin.)
Q3. i used this circuit with BQ24640 with some change . (schematic attached ) after some days I found that Bq33100 constant current load section used for ESR & capacitance measurement are burnt out . please suggest how can we avoid.
Q4. when we control the LLEN pin through software it is showing random behavior. Sometime it functionally well , sometimes not . it doesnot work well when ESR & capacitance enable & super cap power goes shut down .
Thanks & regards,
Shivam
