UCC25600: UCC25600 operation question and request for schematic and PCB review.
Part Number: UCC25600
Hi, TI expert.
UCC25600DR was applied to the LLC Block of SMPS.
Inquiries regarding the use of UCC25600, circuit diagram and PCB review request.
(The circuit diagram and PCB are difficult to disclose on the web, so if you tell us your E-mail address, we will deliver it through E-Mail. Please tell us your E-Mail address.)
[SPEC]
- AC Input : 220VAC
- LLC Block Input : DC 390V
- LLC Block Output : DC 361.5V , 1A (361.5W)
- LLC Transformer Spec
1. Question about the LLC operation.
(UCC25600DR)_LLC_BLOCK_question.pdf
FET dies during LLC Block operation.
I thought that the output current was excessive, so I tried lowering the output current and operating it, but the result is the same.
Question 1) On the waveform, it appears that the gate waveform between the high and low sides overlaps. Is it correct? Which part should be corrected?
Question 2) The current rises momentarily after switching off in the waveform. Which part should be corrected?
Question3) I request a review of the circuit diagram and PCB file. (Please let me know if there are any parts that need to be corrected.)
Please check and answer.
Thank you.
