BQ27546-G1: How do I make BQ27546-G1 work properly
Part Number: BQ27546-G1
Other Parts Discussed in Thread: BQSTUDIO, GPCCHEM, EV2400
Dear All
     I used this IC for the first time, so I don't know how to make it work. Right now I need to use it on the android o1 mtk  platform.
I used the defualt driver bq27x00_battery.c for kernel-3.18, and keep it working.I2C is communicating normally.However, the Battery
voltage is currently only available correctly.  Some of the other information is incorrect like Battery capacity =0, State of Charge =0.
I don't know what configuration is required for this IC to work normally. Which registers should be put in to record the battery information.
Hope someone can answer this question.
Thank you for your time
