Other Parts Discussed in Thread: TPS7A39, TPS65130
I ordered a couple of TPS7A39EVM-865 eval PCBs to test noise performance of the dual LDO regulator.
I was looking at the schematic of the eval PCB and noticed that the values of resistors that set the output voltage are way different from the recommended values in the TPS7A39 datasheet.
EVM Schematic +/-5V output:
- Positive output voltage divider pair:
- R5 = 249k
- R1 = 76.8k
- Negative divider pair
- R6 = 280k
- R10 = 66.5k
TPS7A39 Datasheet +/-5V output:
- R1P = 32.4k
- R2P = 10k
- R1N = 42.2k
- R2N = 10k
Why the huge difference? Did the engineer who designed the TPS7A39 Eval PCB figure out a better configuration or did they not read the datasheet?
I am looking to maximize PSRR and for lowest peak-peak noise. What are the correct recommended values for this part?
