Hi Sir,
A customer has a design issue on UCC28180.
can you share your valuable suggestion?
When I use ucc28180 for DC boost control chip application,
I found that under the condition of load in the front section of power supply,
there will be automatic shutdown at the moment of load, and then restart,
I also monitored, ucc28180 trigger protection only current loop open circuit ISOP,
but voltage loop open circuit OLP, VCC under voltage UVLO, icompp, all did not trigger,
Please find my attached pictures.
green is vboost voltage, blue is input, yellow is icompp,
the green waveform after turning off is hardware under voltage protection.
Thanks a lot.
