What are all the modifications required to use the above control circuit for 440VAC.
Mosfet, transformers will be selected according the rectified pk voltage.
Kindly suggest for thr required modification in the control circuit part.
Hi Arun,
Almost all of pins of UCC28610 are" low "voltage pin , so there is no special modification needed. but all of X-cap and Bulk cap voltage rating should pay attention. you have to change to higher voltage rating. and my recommendation is you can download the calculation tool for your design.
Thanks.
