Other Parts Discussed in Thread: UCC28610
Could you please let us know the BOM LIST of “Figure 12. Disable Skip Mode” circuit which datasheet P.15 shows?
Please advise us.
Thanks and best regards,
M.HATTORI.
Hi Motoyasu,
The purpose of Zener in the circuit is to generate a stable voltage , but VCC of UCC28610 already is a 8V stable regulator output voltage . so Zener is not necessary . you can refer to Figure 14. Typical Application Circuit . and equation (24), if R22 resistor is 100ohm , calculated R21 is 6.49k. the circuit must produce a 125mVdc level voltage on CS pin.
Thanks.
