We use the above LM2592HVT-ADJ/NOPB for several years, and so far has no problem until the last production of 550pcs in Dec. 2020 but already result in 60pcs burn out between input/output lead plastic. Which causes our closest attention and can't find any mistake on test setup, layout, component. Then we send the good/failure parts to third-party lab. analysis by de-cap the plastic. And only can find the input/output area is in melting. Besides that, no significant difference between the good and failure parts.
Since all failure parts are marked with "7CABTTUG3 followed with LM2592HVT-ADJ P+". Please help and check whether you have any record of this? Is it your company date/plant code? And what does it mean? Is there any quality report on this code?
The input voltage of this LM2592HVT-ADJ/NOPB is 50Vdc and output is adjusted to 13Vdc.
