Other Parts Discussed in Thread: TPS53681, , CSD95485RWJ
Hi:
Excuse me,I see on datasheet TPS53681 match up CSD95490 MOS,TPS53688 match up CSD95485RWJ,
so:1) I can TPS53681 be replaced by TPS53688?
2)can use TPS53681+CSD95485RWJ?
thanks
Hi:
thanks
Yes, TPS53688 can replace TPS53681. However, note they are not exactly pin-to-pin compatible, so you would need to change the layout, and the PMBus command sets are different.
Either TPS53688 or TPS53681 are fully compatible with CSD95485.
