For the high side MOSFET(PDC3908AZ) of the synchronous buck application(TPS51215A), we found that Vds and Vgs are ringing as output load is increasing. The amplitude of the ringing waveform at heavy load is bigger than at light load. But there is no ringing by using other MOSFET(NTTFS4C10N). Does the ringing syndrome relate to any MOSFET parameters?
The waveform is showed as below:
No load
Max load
