TPS65130 team,
We have an audio customer seeing noise in the audio band on the negative output of the TPS65130. They a slight increase in the noise at around 2 to 3 kHz before the noise drops off at higher frequencies.
Adding a capacitance on the negative output increases the hump at 2 to 3 kHz. Reducing capacitance will increase the noise broadly at lower frequencies.
They have a 4.7nF cap on CN, as recommended. Can this cap be adjusted to help with this? Does it make sense to add a series resistor here to change the compensation network?
I think a series resistor is being recommended here:
Any advice on what to try?
Darren
