Hello TI Experts,
We are planning to use BQ25606 as part of the charging circuitry for our upcoming product. As part of this, during the charging, we would like to charge the battery as well as power a load simultaneously. However, we do not want to use the BAT pin for both these purposes. That is, the BAT pin will be connected to the Battery alone. Is there another provision as part of this charger to drive a load? As per our understanding, the SYS pin can be used for this purpose. But, we do not have sufficient information from the datasheet to make our design. Please let us know the following information to proceed with out design:
1. Can we use SYS pin to power/drive a load (the load will be a boost converter) while charging?
2. If SYS pin can be used for this purpose, what is the maximum current and voltage that can be supplied to the load? Will there be a voltage/current fluctuation during the charging phase?
We look forward to hearing from you!!
