We have an application that the CFETF permanent failure is falsely triggering. Our pack is removable thus the PRES pin is toggled often to send the pack to sleep.
I do not see any current paths that would cause the current across the low side sense resistor.
Our sense resistor is a 0.5mOhm resistor and our CFETF parameters are 10mA for 5 seconds. I am assuming this is caused by noise in the sensing, as 10mA is a very low voltage to measure across the sense resistor we have. Is this a known issue based on the thresholds we picked?
