I see the Qualification summary of TPS2511DGN.
Is that component is not test about wire bond?
Could you please explain this qualification? I am not familiar with it.
Emma
Qualification summary is https://www.ti.com/qualificationsummary/qualsumm/home?actionId=2800 link in your site.
please check that.
I am not following your question. Is there something you needed in the qualification summary that is not there? Or do you have a question about the qualification itself?
Emma
I am checking in with our team to see if we have this test.
Emma
It is not standard practice on our commercial versions of devices to have any Wire testing beyond the typical inspections/tests during the assembly process. However if you use the qualification tool to look up the automotive version of the TPS2511 (TPS2511QDGNRQ1) you can see Wire Bond Pull testing
