Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
CSD18510Q5B: How to more accurately predict the Reverse Recovery losses in FETs/Diodes
Part Number: CSD18510Q5B
I'm trying to predict the losses in DC-DC converters using only datasheet information where possible. One of the parameters that I haven't had much luck with is the Qrr/Trr related losses.
In most datasheets, the Qrr losses are only specified for one operating condition, but from some of your training material (https://training.ti.com/understanding-mosfet-datasheets-switching-parameters https://training.ti.com/reverse-recovery ) and other research papers, these losses can vary a lot with changes to di/dt, forward current before reverse recovery and temperature.
My question is: Is there any equation that you can apply to datasheet Qrr/Trr parameters to correct for different operating conditions? For example, if my application the di/dt is closer to 1000A/us, rather than the 300A/us specified in the CSD18510Q5B datasheet (a random FET I chose), is there a scaling factor I can apply? How to scale for different di/dt and I_F would be what I'm looking for mainly.
Kind regards,
Oisin Anderson
