Dera TI Experts,
I am using the BQ24040 to charge 400mah lipo batteries. You can see my settings in the attachments.
sn_customerservice_case_eb3b433f1ba3a4d0602cf715464bcb02_attachments.zip
I am charging the battery at 0.5C (peak) and it takes more than 6 hours to charge. I noticed that after 3h it stays at 15mA for hours ...
My doubts:
1) what is happening? this is normal?
2) Is my configuration correct?
3) What current setting do you recommend I use for a 400mAh lipo battery?
4) I am using a 115 ohm resistor for the LED. Is this too low?
Thank you in advance.
Jonard Rico
