Part Number: CSD13381F4
In CSD13381F4 12 V N-Channel FemtoFET MOSFET Top view a body diode is simulated between the source and the drain which is common and available in all the mosfets.
However, a diode between gate and source of the mosfet is also simulated.
Could you please explain the functionality of this diode (between gate and source) and if it is available in all the mosfets or only this particular part number?
Leakage current could appear between gate and source if the source voltage is high and the gate is connected to ground for an off state of the mosfet?
Kindly advise.
