We have an application that requires the bq34z100-g1 to be switched off. An EEPROM would then save the last SOC value.
When switching on, the controler would write that value back in bq34z100-g1. Is it possible to write a soc value?
The trm says it is a read only access, but could you confirme it?
the deviation of the chem ID is such that the value found by the OCV readings wouldn't be so accurate.
thanks
