TPS65131: +/-22V, 1W power solution for an input of 5~15v
Part Number: TPS65131
Other Parts Discussed in Thread: DAC81416,
I want to use the full output swing of +/-20V from DAC81416. I have found an IC
TPS65131 but this is only between +/-15V. Is there a chip similar to this that can
provide a higher output range? Or is there an appnote power design solution to
provide +/-22V for DAC81416. I'm looking for a solution that can provide around
a watt with +/-22 for Vss and Vcc of the 81416. The input voltage is 5~15v.
This is a cross-post to Data Converter forum: https://e2e.ti.com/support/data-converters/f/data-converters-forum/998660/dac81416-power-solution-for-output-range--20v/3689699#3689699
Thank you so much.
