BQ40Z50-R1: BQ40z50-r1
Part Number: BQ40Z50-R1
Hi
Once the learning cycle is done and gg file is extracted. The battery pack is qualified for using in devices??
The Same gg file can be used in the production right ??is it necessary to change  anything gg file before uploading.
  • Hi Anandan,
    We recommend you configure and run learning cycles on multiple batteries and averaging the results before taking it to production. I recommend you take a look at this thread if you have only used one battery sample. After that, you do not need to change anything in your gg file but you will need to extract a golden image.
    Jessica
  • Hi Jessica
    Thanks for the reply.
    Once learning cycle is done.I have Extracted only the gg file and uploaded on another battery packs.
    What is that golden image? Is anything to be Extracted and uploaded.
