BQ34Z100-G1: how to stop impedance trackig
Part Number: BQ34Z100-G1
hi,
I've got problem with learning cycle for impedance tracking: the charger I use checks impedance of battery each 31 seconds. Such charging permits the algorithm to work properly (green: voltage, pink: current). at the the end of charge/discharge cycle the cell capacity is estimated correctly but "update status" is always 0x04 indicating the algorithm running and did not succeed. How can I stop it so I can make file for production? Ideally it should be 0x02
