A coulpe of questions:
1) During my trial to obtain a Chem_ID following slva725a.pdf I only managed to get one that obtains a 5.5% error.
How do (what is the best way) I send you samples of my battery to be characterized for a proper Chem_ID? What is the procedure and how long should it take?
2) Using this Chem_ID I started following slua903.pdf for the training cycle.
I'm running the training cycle on the BQ27Z561EVM-011 with my battery.
The training cycle failed during the first charge-to-full.
If I understand correctly it fails because the battery was not charged by more than 90%.
I do not see what I need to fix in order to achieve a proper training cycle.
Attached are the report I got as a response from the Chem_ID tool and the registers log of the charge-to-full.
Thank you,
Ofertraining_seq_Vempty_32_charge_to_full_log.logGPCPackaged-report-VEmpty-3.2.rar
