BQ25731: terminates charging
Guru 29720 points
Part Number: BQ25731
Hi Team,
Is it a reasonable way to apply low level to ILIM_HIZ to terminate charging?
I would like to know if there is a way to terminate charging with pin control (not I2C access).
Yaita
  • Hi Yaita,
    Yes, you can disable charging by putting ILIM_HIZ under .4 V. When the pin voltage is under .4 V, the charger will enter high impedance mode (Table 7-1. Pin Functions, pg.6)
    One way to do it is with a GPIO switching from from high impedance to sink (GND the pin). It will have minimum effects to other operations when you don't want to pull ILIM_HIZ to ground.
    Peng
    *If my answer solves your question, please press "This Resolved My Issue" on the thread.
