Hello, all.
Now we trying to use TPS386596 on our PLC board, but this is the 1st time to use TI's voltage supervisor device.
On our experience, we have only used LTC1728.
Now I am referring TPS386596 datasheet, then found one description which need to be clarified as below;
On page6, I found the following description.
It is good analog design practice to use a 1nF to 10nF bypass capacitor at the SENSEn input to ground, to reduce sensitivity to transients, layout parasitics, and interference between power rails monitored by this device.
Meanwhile, our experience to place bypass capacitor on LTC1728 is following method.
Would you please let me clarify whether the bypass capacitor should be placed as same method as LTC1728?
Thank you in advance for your information.
