Part Number: EV2400
The EV2400 is recognised by the most recent Battery Management Studio, but so far has failed to communicate with four different bq40z50R1 chips on different boards. I have checked that the 3.3V supply for the SMbus is working. Only one of the BMS setups had a set of 4 cells connected. Should I expect any communication if there are no cells to recognise? If not, is there any way, short of changing the chip, that I can discover if the BMS with the cells connected has failed?
Andrew Armstrong
