Part Number: LM27762
Other Parts Discussed in Thread: TL072, , LM2772
Hi, all!
I need to read the output of a photodiode through TI Hercules RM57Lx, with the onboard ADC. The photodiode gives a negative voltage, so I have made an inverter circuit using TL072 IC.
The issue is that TL072 IC needs a negative power supply as well. I was using two 9V batteries to provide the +ve and -ve voltages but I need a constant power source. Is LM27762 IC a reliable option?
If not, please, suggest.
Thanks and regards,
Apurv
