Other Parts Discussed in Thread: BQ25070
How should we select charger device for LiFePO4 battery?
Can we use any Li-ion battery charging device if charge voltage is match with used LiFePO4 battery?
Or is special feature required for LiFePO4 battery charging?
According to bq25070(LiFePO4 charger) datasheet, I think charging profile is different from Li-ion battery charging profile.
For LiFePO4 battery charging, is this behavior required? "CC charge -> OVCH detection -> Float voltage regulation"
I think this doesn't have taper current detection. How is the full charge detected?
Kohei Sasaki
