TPS61193: output voltage is lower than normal level and display dimmed dark during power up
Part Number: TPS61193
Hi team
customer use TPS61193 in below application, found the output is lower than noraml(22V) and display light black during power up
input is 12V battery, EN/PWM is normal, FAULT pin is hight. I attached customer issue description include scheamtic. could you help to check it? thanks.
backligh dark.docx
